3 members (Hotrod Lincoln, Guitplayer, Robert Crandall), 86 guests, and 2 robots.
Topics128,154
Posts1,056,838
Members48,456
I
I Offline
I removed the original carb because it was leaking between the top plate and the body of the carb. I tried to tighten it down to seal the gasket but it looks like the top plate of carb is warped. My question is where do I find a carb or adapter plate that is small enough bore to fit on there? I have an Edelbrock but the gasket is too big to seal up around the intake. I also have a Q-jet adapter plate but same thing the gasket is too big. What kind of gasket do I need or what carb fits other than another OEM carb?
My new 1949 Chevy One Ton Dump Truck. Still have it but parked, needs a new motor.
1953 2 ton parts truck Long Gone
1957 GMC LCF On 75 Cadillac Eldorado Frame
Updated Feb 2021
H Online: Content
Here's the one you need, and the price is right, too.
http://cgi.ebay.com/ebaymotors/Carb...Z020QQcategoryZ33550QQrdZ1QQcmdZViewItem
The original 348 carb was probably a Rochester 4GC, with a small square bolt pattern. This adapted was intended to allow the installation of a Carter AFB, which is the carb Edelbrock copied.
Carburetion specialist
All of the 348 carbs whether Rochester or Carter have the early rectangular bolt pattern (aka the Carter pattern). This pattern is 4 1/4 wide by 5 5/8 long.
The so-called "square" pattern was used from 1952~1956 (before the 348) and was 3 13/16 wide by 3 15/16 long.
A problem often arises within various carburetors of the "Carter" pattern in that the throttle bores were moved apart (from side to side) on center 1/4 inch on most units about 1961. Thus a 1962 carb, while it may bolt to a 1958 manifold, may experience throttle plates that will not open due to the center line change.
(Opinion) You will like your original (after you rebuild it) better than you will like the "clone", and for a longer period of time.
Jon.
The Carburetor Shop
I
I Offline
Quote
Jon.
Being new to the Big Bolts please explain to me more about that statement. I just want my truck to run, not at all worried about it "being original" In my original post I said the carb that is on it I don't think can be rebuilt. The top plate of the carb looks warped. A buddy looked at it today and said "what the heck, it looks like some one was prying on that with a screwdriver". It dumps gas out the top whenever it is running. I took some pics of the damage and will try to post them. I don't know if they will show up.
Updated Feb 2021
I
I Offline
Are you guys sure that adapter on ebay will work to put another one on. I took the carb and gasket to FLAPS this morning and they looked at it and said have to order one but they had no idea what adapter or gasket to order.
Updated Feb 2021
I
I Offline
http://i46.photobucket.com/albums/f129/Ibendcars/62ChevyCarb1.jpg
http://i46.photobucket.com/albums/f129/Ibendcars/62ChevyCarb2.jpg
Here are the pics, the best my camera phone can do, but they show where the top plate is warped/seperated for the bottom piece.
Updated Feb 2021
Quote
Originally posted by IBenDcars:
Quote
[b]
Jon.
Being new to the Big Bolts please explain to me more about that statement. I just want my truck to run, not at all worried about it "being original" In my original post I said the carb that is on it I don't think can be rebuilt. The top plate of the carb looks warped. A buddy looked at it today and said "what the heck, it looks like some one was prying on that with a screwdriver". It dumps gas out the top whenever it is running. I took some pics of the damage and will try to post them. I don't know if they will show up. [/b]
If the airhorn has been damaged, repair may be a job for a professional (or acquire a different airhorn from a carburetor of the same tag number). I personally would still redo this one above using one of the clones. Others may have differing opinions.
Jon.
The Carburetor Shop
