1 members (RLB), 215 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
I need to move my truck, but i removed the gauges to prep interior. I temporarlily placed the gauges back in the dash so i could insert the temp. sensor back in the block so i could move the truck to the back yard. I didn't want to wire the gauges back up as they will be comming right back out. The truck is having some problems starting, but it has been sitting awhile. Is there any reason the gauges not being wired up would prevent it from not starting? I did not think so, but thought i would check with you all before i wasted any more time.
Darren.
[Linked Image from i1188.photobucket.com]
3B Offline
Hy gtreasur, if you're hot wiring the truck no gauges are required, don't forget to plug the oil line to the gauge, and the water temparature probe hole.
Oh i forgot about the oil line, thanks.
