0 members (),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | I need to move my truck, but i removed the gauges to prep interior. I temporarlily placed the gauges back in the dash so i could insert the temp. sensor back in the block so i could move the truck to the back yard. I didn't want to wire the gauges back up as they will be comming right back out. The truck is having some problems starting, but it has been sitting awhile. Is there any reason the gauges not being wired up would prevent it from not starting? I did not think so, but thought i would check with you all before i wasted any more time.
Thanks, Darren.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy gtreasur, if you're hot wiring the truck no gauges are required, don't forget to plug the oil line to the gauge, and the water temparature probe hole. | | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | Oh i forgot about the oil line, thanks. | | |
