1 members (klhansen),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79993 07/14/2007 2:53 AM | Joined: Oct 2006 Posts: 63 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 63 | Diving into new project, '53 1-ton. Found answers to some questions - here's another question: I installed a 12-volt foot activated starter from a salvage yard that is compatible (gear wise) - I just don't know what the little switch gizmo is on the top (not the main foot pedal switch). This is a little cylinder-shaped thing (a little smaller than a tobacco chaw can) with three electrical posts on it - it seems to be a switch that gets activated when the starter is activated. I can supply pic if this is too vague. I'm having some trouble with the starter engaging the flywheel gear - this isn't some kind of switch to engage the flywheel gear is it? new: http://Alignment2012.com/1953chevy.html | | |
#79994 07/14/2007 4:30 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Colorado51three quarter, The switch you are describing is a polarity reversing switch, it's purpose was to change the polarity of the power flowing through the points [primary ignition cicuit], it would change the polarity every time the engine was started. Now to your engagement problem, 12 volt starters are not compatable with flywheels designed for 6 volt starters. As long as your engine doesn't require a lot of cranking when starting, your 6 volt starter will work just fine on 12 volts, hope that helps. | | |
#79995 07/14/2007 5:01 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I ran a 6 volt starter for years with a 12 volt system. As long as you don't have to crank it for a long period of time, it will function correctly. If you crank for a long time, they will overheat and the armature will expand causing the starter to drag. If you change to a 12 volt starter, you will also have to change the flywheel to have the appropriate number of teeth to function with a 12 volt starter. The 12 volt starter teeth look the same and look like they will match up, but they will not. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
