9 members (Wayne67vert, TooMany2count, Nick in Manitou, NJC, Mike in Sycamore, Bill Hanlon, Ponchogl, sron48, rfs56trk), 85 guests, and 4 robots.
Topics128,137
Posts1,056,747
Members48,454
#799864 11/22/2011 3:20 AM
Reworking the roof on my 51, my drip rails are pretty beat up and i was thinking about replacing them. Any suggestions or advice would be nice. I'm hoping to see some pictures of the drip rails off the truck and some pictures of what that area of the cab looks like after they are removed. OR
if you repaired loose,leaking and dented drip rails what did you do?
Y
Y Offline
I removed the drip rails on my 54 AD. The "gap" in the door opening will probably need some work to make it look right. I actually had to rework the left door upper frame to close the gap. I got the idea after seeing a 54 in one of the trucking magazines. I think most of the custom builders remove the drip rails so that they can get that slick clean look. As far as replacing drip rails, find a doner and drill out the spot welds carefully and tack them on your truck.
For leaks on my 1-ton, I just used some seam sealer in there, before paint. No drip rails mean lots of water falls into the truck, although I bet if you have a really nice truck, you probably don't drive in the rain!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
