| | | Forums66 Topics128,154 Posts1,056,842 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 12 New Guy | | New Guy Joined: Aug 2009 Posts: 12 | Reworking the roof on my 51, my drip rails are pretty beat up and i was thinking about replacing them. Any suggestions or advice would be nice. I'm hoping to see some pictures of the drip rails off the truck and some pictures of what that area of the cab looks like after they are removed. OR
if you repaired loose,leaking and dented drip rails what did you do? | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I removed the drip rails on my 54 AD. The "gap" in the door opening will probably need some work to make it look right. I actually had to rework the left door upper frame to close the gap. I got the idea after seeing a 54 in one of the trucking magazines. I think most of the custom builders remove the drip rails so that they can get that slick clean look. As far as replacing drip rails, find a doner and drill out the spot welds carefully and tack them on your truck. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | For leaks on my 1-ton, I just used some seam sealer in there, before paint. No drip rails mean lots of water falls into the truck, although I bet if you have a really nice truck, you probably don't drive in the rain! | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 |
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
