| | | Forums66 Topics128,032 Posts1,055,521 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 101 | When installing the carb spacer should there be a gasket between the manifold and spacer, and the spacer and the carb? On my 54 chev 3100 with 62 chev 235.
Disciple
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Ted,
The Shop Manual shows/mentions no gaskets.
However, I'd say that almost everyone uses a gasket between the carburetor and the spacer/insulator. Be sure that there is a notch in the gasket to match the hole in the base of the carburetor.
The gasket between the spacer and manifold is probably not used by a majority of people, unless there is a leak or unless they want a failsafe against a leak. Using a gasket in that location causes no harm.
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | after some engine work some time ago i had a pesky intake leak come to find out i forgot to put the gasket on between the intake and the insulator. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I just purchased an insulator off ebay to use with my rebuilt carb and it came with two gaskets. My existing setup that came w/the truck also has both. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Ted - I wrote a similar response to another post recently. I don't use gaskets with the insulator on my '54 3100 235. I have no leaks. Gaskets raised the heigth of my carb thus making the accelerator rod to the carb too short. The throttle butterfly would not open fully. The insulator and carb rod are originals that I purchased from forum members. It's possible that they are from a different year 235, or that accelerator rod assembly bellcrank is worn, but bottom line - everything works.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jan 2009 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 101 | Guys, thanks for the info. In reference to Lonnie's message. I can see where if I install the insulator and gasket, there probably will be a problem with my accelerator rod not being long enough. I have a extra rod, and it and the one on my truck are the same length. How in the world would the insulator and gasket have worked with either of these rods? How did they come from the factory? Is there something I am missing here?
Disciple
