2 members (baldeagle, Oswald), 42 guests, and 10 robots.
Topics128,012
Posts1,055,316
Members48,419
#799266 11/20/2011 12:17 AM
can our stovebolts run on moonshine,,, I know the electronics.. lol the coil and points will live after a EMP pulse from a nuke.. so we well still go down the road.. but if we had no more gas.. could we use grain alcohol.. home made... to run the trucks,,,, I know we would have to jet up big... and food for thought.. because I see doom in this country...
I like fixing stuff.
katrina #799268 11/20/2011 12:23 AM
I see problems with seals and o-rings. Alcohol eats some of that rubber for lunch!
katrina #799280 11/20/2011 1:28 AM
Getting the alcohol above 140 proof (70%) is a difficult job, requiring some very sophisticated distillation equipment. It takes two runs through the still to get it up to that strength for aging when making Bourbon, or any of the other distilled spirits. The still we ran at Gallo Winery produced 99.5% pure alcohol for fortifying certain wines, but the still was 5 stories tall, 10 feet in diameter, and the alcohol went through about 4 stages of distillation before going to a water-chilled condenser. The production capacity was 2,000 gallons per hour. It was not exactly a backyard operation!
Hotrod Lincoln #799304 11/20/2011 2:29 AM
I think you'd be better of using a wood-gas generator, than using alcohol. That can be a backyard operation, but requires lots of experimentation to keep the gas clean, and not tarry. Expect a 30% drop in power.
I hope you keep your spare coil in a faraday cage, I know I do. Hahahahaha!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Hotrod Lincoln #799365 11/20/2011 5:33 AM
Spoken like a true Tennessean.
~Jim
BIG CHEVY 3600 #799382 11/20/2011 8:46 AM
Got a better idea- - - - -if it's good-quality stuff, put a little in me, and I'll help push the truck!
grin grin grin
Hotrod Lincoln #799436 11/20/2011 4:58 PM
Set up your truck for propane conversion, then buy a big storage tank.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
jmoore #799603 11/21/2011 3:32 AM
sps Offline
Gets that bad, You won't have any cities to drive to. Might as well stay on the farm.
sps #799993 11/22/2011 4:28 PM
I've seen a DeLorean that runs on garbage. Maybe you could rig up something like that. wink
BLUEMEANIE #799998 11/22/2011 4:46 PM
I just watched "Last man on Earth" starring Vincent Price. Looks like there will be lots of gas left to run my station wagon. Gotta get home by dark!
It's a terribly great movie. And you can watch it for free.
http://www.archive.org/details/the-last-man-on-earth
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Mr. Lang #800008 11/22/2011 5:37 PM
Carburetion specialist
C Online: Content
If you use "moonshine" will you pay road tax or consumption tax? Gotta keep the feds happy!!!
And if you are truly serious, read some of the E-85 threads on various forums.
Jon.
The Carburetor Shop
BLUEMEANIE #800135 11/23/2011 1:36 AM
Amazing, I've driven garbage.
~Jim
Mr. Lang #925712 03/08/2013 8:33 AM
what electrical parts on our advanced design trucks would be subject to EMP , not that it could ever happen.....right
katrina #925781 03/08/2013 1:47 PM
1 Offline
Back in the late 1970's and early 80's there were two brothers from Clements MN who designed a corn alcohol still on their farm and used the ethanol in a 1950's ford pickup truck. I saw this pick-up in operation and remember the smell of the exhaust when they drove this truck into the local grain elevator. It was the beginning of the ethanol industry. I do believe these two brothers are still alive. Jerry
P.S. to carbking regarding Road tax or Consumption tax on moonshine used as vehicle fuel, The ethanol plants have to add a certain % of Gasoline to the finished product or pay Consumption tax on it. It is then called "Denatured Alcohol"or unfit for human consumption. I kinda think that the 2 brothers above paid neither tax. LOL
katrina #925784 03/08/2013 1:57 PM
sounds like a great idea and i would do it, but as i recall it's illegal frown
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
katrina #925794 03/08/2013 2:59 PM
materman, pretty sure all you need is a Alternative Fuel permit now. You must add some gasoline to make it non-drinkable.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
64fleetside #925807 03/08/2013 3:32 PM
After you check it for purity. LOL
~Jim
katrina #925808 03/08/2013 3:35 PM
My Father during WW2 was a Partizan in the Alps,and told me that they would run there trucks with a fire box mounted to the front of the truck,the truck would run on just the fire from that box.I saw a show not that long ago and they ran a truck the same way.I think this summer I'm going to see if I can get a old lawn engine I have to run on a fire box.
Pete
Pete52 #925810 03/08/2013 3:42 PM
Pete
What is a "firebox"?
~Jim
katrina #925824 03/08/2013 4:23 PM
All He told Me was it was a steel box and they would build a fire in it and after the fire was hot they would close up the box and it had a pipe going to the top of the carb and the truck would start and run.
Pete
katrina #925825 03/08/2013 4:38 PM
a fire box is used to create wood gas as Mr. Lang stated.
If you burn wood at temps greater then 400' then petrolem by product is created . you funnel the smoke and lead it into your generator
interesting video. cool looking inline ford generator.
you know one thing I was thinking about. say we were in "martial law" and they flew over and emp'ed us, your truck would be sure to draw the attention of drones. (if your the only non military vehicle moving around.) frown
katrina #925827 03/08/2013 4:42 PM
heres another,
katrina #925829 03/08/2013 4:48 PM
It's called a gasifire just watched a guy splitting wood with an engine running on a 5 gal steel buckit filled with charcol.Nice.
Pete
katrina #925924 03/08/2013 10:10 PM
The correct name, I believe, for these devices is gas producer.At least that was how they were named in the old engineering books dealing with early Internal combustion engines.Liquid fuel was not so successful in the IC engine until about 1890 and even for a while after that when they were called on in remote areas the fuel would usually be a gaseous fuel and the gas producer was many times supplied by the engine maker.The fuel for the gas producer could be about anything that would burn-from coal or peat to wood products and sugar cane stems (bagasse).In operation a fire would be built in the "firebox" and the draft was choked back so that combustion was incomplete and the smoke or fumes was led to the "mixer" on the engine to be mixed with air and admitted to the cylinder.The efficiency and output quality of the producer/engine was variable and required close management to work.Engine life was poor because of impurities it had to deal with but it was still ahead of the steam engine.We have occasionally seen pictures of buses and trucks in less developed countries with a gasifier hanging on the back bumper and there is a Mercedes (about late 30's) in the Lane Motor Museum in Nashville with a producer built into the left front fender.3 years ago at our local car show in Waverly TN a 50's chevy truck was hauled in with a home built gasifier in the bed.He ran it for us but he was still working on some details to improve the performance and was driving it about in his home town in west tennessee. (Paris or Milan I think).
Bob Taylor
katrina #925931 03/08/2013 10:57 PM
For a little information on a unusual application of a producer-do a search for "humphrey pump cobdogla".This is the only actual Humphrey pump still in existence.The Humphrey pump is actually an internal combustion engine with a liquid piston-which is the fluid being pumped.This one in Cobdogla Australia is the existing one of a pair installed to dewater a huge area and due to it's huge appetite for fuel and remote location, had a large gas producer set up to burn the local wood. This thing moved 1.25 MILLION gallons of water per minute. A good description and pictures of the pump here but the producer is long gone.
Bob Taylor
