Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (SWEET, Wickedbass, Hanks custodian, HandyAndy, Ponchogl), 40 guests, and 2 robots.
Topics128,009
Posts1,055,297
Members48,419
I just rebuilt the front end on my 50 3800.
New king pins, shocks, tie rod straightened and new ends. dance
Pulled the pitman arm and the steering arm, had the holes welded up, drilled and reamed to fit a modern tie rod. I took the old drag link and tried to measure approximate centers but everything was a mess. I came up with 12.75". headscratch
Is there a length that is correct?
How do you know?
I should have this right before I adjust the toe-in... right?
Almost done...
Jeremy
San Jose
1950 Chevy 3800 1-Ton Long Bed
More pix on Flickr
Sold all the bikes, leaving California behind.
3B Offline
Hy lostmy47, center the steering box, set the front wheels to the straight ahead position, now measure the center to center distance between the pitman arm and the steering arm. This should be your drag link center to center measurement, If you're making an adjustable drag link, put this measurement close to the center of your adjustment range. Toe in will not effect this distance, and it will not effect toe in, that is set with the tie rod positioning, hope that helps.
Thanks! got it.
More pix on Flickr
