| | | Forums66 Topics128,140 Posts1,056,771 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 112 | So what's the secret to successfully pushing the fuel filler neck through a @#$% new grommet from the inside? | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Wish I could tell you what a '69 is like, but on my '58, I remember removing the neck from inside the cab, then lubricating the neck pipe with some vaseline. That allowed me to slip the grommet on. From that point, I put the grommet/filler pipe into the thru-hole and incrementally adjust the pipe/grommet so that the grommet fit back into the hose in the cab that goes to the fuel tank.
Bill | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | | | | | | Joined: Oct 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 112 | | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Ditto to the dish soap... great for windhield/back glass installation too. Slicker'n all getout! Jerry | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Uh oh. Mine just slid on. Umm... hope it doesn't leak. | | | | | Joined: Oct 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 112 | So I've pulled out the seatbelts in addition to the seat because they were annoying me, applied dish soap to the grommet and filler neck...and STILL can't get the neck through the grommet! I'm a little perturbed.
It appears to me to be an angle of assault issue. Does anyone have any tips for twisting or turning the tank a certain way to push the neck through in my '69 C-10? | | | | | Joined: Oct 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 112 | At least I can clean up the setbelts a bit! | | |
