10 members (sron48, Donf, Bill Hanlon, rfs56trk, Hanks custodian, Wally / Montana, ranchojuan, jkreiner, fonz8261, TexasJim50),
49
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,914 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | I'm a little confused. I have a turn signal switch that is mounted near the bottom of the steering coulmn (see link #18 in LMC catalog). http://www.lmctruck.com/icatalog/cbe/full.aspx?page=100I am about to order #12 from the following link. http://www.lmctruck.com/icatalog/cbe/full.aspx?page=82My question is how do the wires attach to the signal mechanism kit (#12 from 2nd link) and then to the switch (#18 from 1st link)? Is there a past post that has pictures and/or directions? As always, thank you in advance!
Thom Masterson
Thom Masterson
| | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | There is a cable that runs down the stearing column where the swith actually mounts. when you move the lever a small arm gets rotated up or down and pulls the cable which gets clamped into the back of the switch. You need to get it set correctly so that when the turn is canceled the switch is centered up. If you don't then your brake or tail light won't light up. I don't remember which one. I never did get mine set right. If I turn right I have to switch mine to the left and then off so it work correctly. When you get the parts or take yours apart you will see how it works. | | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | Thanks for all your help. Turn signals work great...except. When I signal left or right, the front parking lights both flash. The rear lights work and flash as they should. I did wire the headlights and parking lights to both be on at the same time when the headlights are turned on, but I don't think that makes a difference. Any ideas?
Thom Masterson
| | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | Since my rear turn signals work fine, could I wire my front parking lamp and rear lamps together on the turn signal switch? In other words, wire the front and rear left lamps on the rear left lamp terminal and the front and rear right lamps on the rear right lamp terminal. I'm thinking that the front parking lamp posts are defective since both parking lamps are getting power at the same time.
Thom Masterson
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | If you do that aren't your front turn signal lamps going to light every time you step on the brakes????
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Do you have dual filament bulbs in the front? If they are single filament for park lights only, they aren't gonna work like you want.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | So jmoore, you're saying I need dual filament bulbs? I monkeyed around with different switches today. My harness rep was somewhat clueless about how to solve the problem. Like most things, I bet it's a fairly easy fix. You just have to figure out what it is. Changing bulbs would fall into that category.
Thom Masterson
