0 members (), 73 guests, and 2 robots.
Topics128,093
Posts1,056,474
Members48,444
#796880 11/11/2011 12:59 AM
folks i need your help once again,im in need of a clutch kit for my 1954 chevy pickup 1/2 ton with 235 motor.could you please recommend some brands and part numbers,i called classic parts.they told me the one they carry is a rhino pac ,when i look up that part number on line,it tells me it wont fit my truck,any help would be appreciated. thanks john
John -
NAPA carries most parts for these older trucks. Give them a try.
Chris
folks im still in need of help with this clutch.The problem is when we got the truck it was all apart.it came with 3 different clutch discs .There was a 10" 11" and a 12" that we found in the bed.so far we have figured out that the 10" that classicparts and jim carter carry ,will not fit, the preasure plate is to small,its not lining up with the bolt holes.did 54 chevy pickups with 235 come with 11" clutch discs?we think the correct one that will work is a 11".thanks folks any help wouls be appreciated. john
thank you tim,might you know whom might sell the 11" clutch kit for 1954 chevy pickup,235,3100,1/2 ton.I see one listed in classic parts,but it is stating it fits 1969-1984.But they do have it listed under the 54 section.What do ya think on this one?
thank you so much john
John,
Here are listing for 1954 large-truck/large-engine clutch parts:
http://www.rockauto.com/catalog/raframecatalog.php?carcode=1326484&parttype=1993
Do you folks know off hand if the 1954 1/2 ton with 235, 11" clutch came with a diaphragm from the factory? If so was it the flat type or the raised type?
thank you john
John,
Here is a diagram. Replacement pressure-plate assemblies will not look exactly like an original.
Good luck,
I have a 54-55 261 with 11" clutch.Sent clutch disk and pressure plate to Jim Carter and they relined clutch and rebuilt pressure plate.I think Patricks has the same service.
