| | | Forums66 Topics128,049 Posts1,055,548 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 46 New Guy | | New Guy Joined: May 2007 Posts: 46 | I have had my 51 panel for about 5yrs now and been a member for almost as long, mostly been lurking on the side lines with not much to say. I now have the time to do some work on it and have the technology to make my own repair panels. However the area I need to work on is totally rusted away, in order to make a reasonable copy, I need to know what it is supposed to look like. If I can impose on someone to take a couple of photos of the firewall meeting the inner fender area it would be most appreciated. Thanks...Roy http://tinyurl.com/7k6u2zd http://tinyurl.com/782jlpe http://tinyurl.com/8xra7eu
It's easier to get older than it is to get wiser.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I don't doubt your ability to make patch panels but the outer cowl panels that are available are probably much less work. Click on webshots in my signature and then on the cab repair album to see my efforts at rebuilding a level of rot similar to yours. Good luck.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: May 2007 Posts: 46 New Guy | | New Guy Joined: May 2007 Posts: 46 | Thank you Curt....That shows me edsackary what I needed to see. Wasn't sure on the transition from the lower part of the panel to the upper part. I get more satisfaction from making my own panels from sheet steel. Just me wanting to see if I can do it.
| | | | | Joined: May 2007 Posts: 46 New Guy | | New Guy Joined: May 2007 Posts: 46 | Got busy today and made up the inner kick panels, still some fitting to do but they are coming. The screws are temporary, I find them faster then clecos and just as easy to remove and replace, the holes will be welded up later. I will be buying the outer skin as time wise it will justify the cost. If you guy's want updates on progress let me know...... http://tinyurl.com/7o253k3 http://tinyurl.com/894ycbj http://tinyurl.com/87onwp9
| | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 |
"If you guy's want updates on progress let me know......"
Yes, of course.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: May 2007 Posts: 46 New Guy | | New Guy Joined: May 2007 Posts: 46 | Small update, decided to buy the outer panels, less work, however I will try to make all the less visible patches for the practice. Bead roller was used to make the beads in the kick panel, they are a little smaller than original but.... http://tinyurl.com/7ek7ukehttp://tinyurl.com/74wwebc
