0 members (), 67 guests, and 3 robots.
Topics128,055
Posts1,055,782
#799011 11/18/2011 7:56 PM
Does anyone know where I can get diagrams on where the vacuum hoses go? I junked a 74 Camaro about 20 years ago and am finally getting around to installing the drive train and suspension in my 49 3100. The SB has the Quadrajet on an Edelbrock Performer intake manifold. There are vacuum hose connections on the front and rear of the the intake manifold as well as on the carb and the shop manuals just say mark them when you disassemble. There are about 6 lines so this could be complicated. Any ideas? I may have to see if I can find someone that has a similar set up locally.
Baba #799019 11/18/2011 8:31 PM
Riding in the Passing Lane
Its pretty simple if you are not going to use the original emmission controls. A 3/8 tube in front goes to the PCV valve. A 3/16 tube that has full vacuum at idle goes to the dist. Power brakes will hook to a pipe plug opening in the rear of the carb or on the intake in back of the carb. Auto trans. modulator hooks to a 1/4 in out let with full manifold vacuum. Cap off any other openings.
1972 Chevy c10 Cheyenne Super
Thanks!
Baba #800278 11/23/2011 11:29 AM
I may have this wrong but I thought the vacuum connection to the distributor at idle should have no vacuum so that the advance doesn't kick in until you hit the gas. Is "full vacuum at idle" correct?
Steve
Yess, you will loose all the vaccuum at full throttle
