1 members (Cosmo),
69
0
Mod | | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Wow, that's awesome hahahahaha. Think of the money you will save on fender welting.
I guess I'd cut that with a zip disc on the grinder. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | yup, my rears were welded on. Very carefully with a disk grinder | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Cutting wheel on a Dotco (angle die-grinder).
| | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | will have to agree with tiny, just use the thin 1 | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | No but I saw a guy weld his exhaust to the frame before. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Cutting wheel on a Dotco (angle die-grinder). x3  Its a slow process but very accurate. FYI: Home Depot has the 3" cut off discs. | | | | | Joined: Nov 2010 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 21 | must have been a factory option , all 4 were welded on to my 40 lol , wonder if there was an up charge , at least they wont rattle , better make the dotco wheels x 4 on approval
Just say no to "BONDO" learn to lead, save a trade  Make something idiot proof .... and they'll make a better idiot ! some days i feel like im living proof  Schubert all things come to those who waite.. as long as they go get it .... Poppa Dave
| | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | I agree with everyone else regarding the die grinder and 1/32 cut-off wheels. It's the best way. I would cut on the fender side not the cowl side. The cut is going to remove material and it may be uneven since it is free-hand.
Good luck, go slow and steady. I would recommend a few pactice runs through some 18-gauge sheet metal to get the feel.
Dale
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | cfbcovers Just a suggestion. I was wondering if maybe you held a piece of sheet metal between the side of the box, or cab & the cutting wheel and move it along as a shield to minimize the cutter & grind marks. Could save a lot of body work later. Part of my left rear fender had been welded on and this seemed to work well for me. Hope this helps out. | | | | | Joined: Oct 2011 Posts: 46 New Guy | | New Guy Joined: Oct 2011 Posts: 46 | Everyone thanks for the input...think i will bust out the die grinder...Vick yes the shield is great idea...thanks will post new pictures when get it done. Fenderless guy if it was a factory option then i now know why the factories are closed. | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | FYI: Home Depot has the 3" cut off discs. Just as a word of caution, not all of the cut off discs carried by the big box stores have a high enough RPM rating for some of the higher RPM cut off/die grinders. Be sure to observe the RPM rating of the wheels you buy are adequate for your die grinder, lest they become a flying projectile. Additionally, the cheaper cut off discs typically put more particulate in the air, quicker. My personal experience has been that the more expensive name brand discs carried by my local welding supply and rated for cutting stainless steel, will put less particulate in the air and make up any price difference with their longer abrasive life. Now lets talk about breathing protection. The throw away dust masks are about only good for fogging up your safety glasses. I use one of the cheaper 3M respirators, the exhalation valves to the side keep the saftey glasses from fogging up, and the seal conforms to your face much better, less chance of breathing all that cut off wheel/steel particulate. | | | | | Joined: Oct 2011 Posts: 46 New Guy | | New Guy Joined: Oct 2011 Posts: 46 | So the breathing mask is important? Never use them just thought they were a nice option.....  JK thanks for heads up FYI: Home Depot has the 3" cut off discs. Just as a word of caution, not all of the cut off discs carried by the big box stores have a high enough RPM rating for some of the higher RPM cut off/die grinders. Be sure to observe the RPM rating of the wheels you buy are adequate for your die grinder, lest they become a flying projectile. Additionally, the cheaper cut off discs typically put more particulate in the air, quicker. My personal experience has been that the more expensive name brand discs carried by my local welding supply and rated for cutting stainless steel, will put less particulate in the air and make up any price difference with their longer abrasive life. Now lets talk about breathing protection. The throw away dust masks are about only good for fogging up your safety glasses. I use one of the cheaper 3M respirators, the exhalation valves to the side keep the saftey glasses from fogging up, and the seal conforms to your face much better, less chance of breathing all that cut off wheel/steel particulate. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | FYI: Home Depot has the 3" cut off discs. Just as a word of caution, not all of the cut off discs carried by the big box stores have a high enough RPM rating for some of the higher RPM cut off/die grinders. Be sure to observe the RPM rating of the wheels you buy are adequate for your die grinder, lest they become a flying projectile. Additionally, the cheaper cut off discs typically put more particulate in the air, quicker. My personal experience has been that the more expensive name brand discs carried by my local welding supply and rated for cutting stainless steel, will put less particulate in the air and make up any price difference with their longer abrasive life. Now lets talk about breathing protection. The throw away dust masks are about only good for fogging up your safety glasses. I use one of the cheaper 3M respirators, the exhalation valves to the side keep the saftey glasses from fogging up, and the seal conforms to your face much better, less chance of breathing all that cut off wheel/steel particulate. Home Depot(I do not know if this is a big box store)http://www.harborfreight.com/pack-of-10-3-inch-cut-off-wheels-for-metal-44812.html | | |
