7 members (FAST55, 2-Ton, Reftys49, Eisenholtz, MickeyP, Oswald, Ponchogl),
117
Mod | | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 13 New Guy | | New Guy Joined: Sep 2009 Posts: 13 | What is the best way to deal with the rust that is inside the doors of my 58 apache. I am going to replace the bottoms and lower skins, so can I do something then when I have the most access? Thanks | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | If it is just surface rust, then clean up any loose rust and paint it with POR 15. You should have really good access once you cut off the bottom of the doors. | | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | I had the doors for my '59 acid dipped. Removed everything including rust! Reveals any and all weak spots. When I cut out the door bottoms I brushed epoxy primer everywhere I couldn't get with the spray gun. Then did it again with a brush on a long stick after replacing door bottoms. Darren | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I recently did the bottoms of my doors and found it was very easy to access them while they were cut out. With the windows out and the doors flat you can reach everywhere. Since I couldn't get a sander of grinder in there I used a wire wheel on a drill bit extension to remove most of the loose rust then, I used a phosphoric rust treatment, made sure I neutralized it well and painted the insides of the doors with rustoleum clean metal primer.(cause its inexpensive and I didn't want to worry about my epoxy primer having issues with the acid) then I applied self healing seam sealer to the panel seams for overkill. There are a number of ways to skin this cat but be forwarned I did find a skinned cat inside one of my doors when I opened it up. Skinned door cat
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | | | |
