| | | Forums66 Topics128,109 Posts1,056,271 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 39 New Guy | | New Guy Joined: Oct 2010 Posts: 39 | I have a 1943 Chevy Fire Truck 6 volt system. I have headlights, running lights when the headlights are on and brake lights. I cant get the flashers/blinkers to work on either the front or the rear of the truck. The rear lights are a two light bulb system (one for brakes and for flashers). Any ideas on where to start checking? Could the blinker switch possibly be the problem? How can I check? Thanks | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I wrote a Tech Tip with a procedure for checking the switch. | | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | Just looked at the tech tip - it is GREAT! Thanks. | | |
