1 members (carbking), 103 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#79824 07/10/2007 1:36 AM
j54
Offline
What rear ends will work well in the 47-55 trucks without shortening or making great modifications? Which vehicles, what are the widths? I'd like one that is narrow enough to set inside the rear fenders and allow a fairly deep- dish wheel with not a lot of backspacing.
#79825 07/10/2007 3:40 AM
I've used the 3rd generation (80's) Camaros in my 54.....they're 5 lug, 62" wide (wheel mounting plate to wheel mounting plate) with a 15X7 front and 15x8 rear but w/4" backspacing. If you're going to do a 5 lug front disc conversion you'll almost be forced to use an aftermarket rim to get clearance. Can't speak to the 6 lug conversion.
There is info available using the search feature that outlines numerous options. At least you know what won't work if you want a deep dish wheel. Hope this helps.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#79826 07/10/2007 3:45 AM
Go to the Tech Tips page and scroll down to Donor Axle Measurements. Plenty of info there.
Drew
