0 members (),
161
Mod | | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 74 | I believe that I have 235 chev 6 and it has a oil bath filter on the carb. Can this be cleaned with gas and if so how. I don't know what kind of material this is made out of. Thanks for your help | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | You should be able to. If you clean it and it falls to peices then it should be replaced any how. Can you post a photo So I can tell you for sure. Down want to give you bad advise. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I'd clean it with kerosene or stoddard solvent instead of gasoline. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Using gasoline for cleaning is very dangerous. Purchase a parts degreaser. | | |
