2 members (55shaker, Steelonsteel), 117 guests, and 4 robots.
Topics128,126
Posts1,056,354
Members48,441
For years I thought my leaky old w-1 was just old and to expect it .
My shed has always had a fuel smell to it, and its always given me a headache. I've had to keep the door open most of the time.
Today I pulled the tin cover off the top of the carb, just to do a bit of a clean and lube the links.
I bumped the throttle link and saw fuel come out the accelerator pump shaft , thru the top of the bowl cover.
Question. Is there a fix for this leak??
Sounds like the float level is way to high. Fuel shouldn't be up that far Dusty.
DG
Denny G
Sandwich, IL
Thanks for the thought DG , I will check that tomorrow.
DG , I checked the float level and its correct.
I pulled the pump and discovered there was a lot of rust stuck to the leather. I cleaned that off , thinking that maybe the fuel was leaking back past the seal where the bits of rust were.
Then I saw a Zenith carb on a spare engine in the shed and decided to try that out , It works great , no more flat spot and no leaking , so if it is as economical to run, I will probably just keep it on the truck.
Then I got carried away and fitted the cleaned up carter to the spare engine , thinking I will give it a test run next weekend , just to see if the engine is ok. (its been sitting for 20yrs) smile
Just as well we do this for fun , eh.
So the engine runs GREAT !! no smoke , no rattles ,, LOVELY smile .
And , the carter off the truck , now on the spare engine has no leaks?? so it must have been the rust lumps on the accelerator pump leather causing the leak .
All's well that ends well, eh.
