| | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 4 New Guy | | New Guy Joined: Nov 2011 Posts: 4 | I have a 54 chevy 3100 that I recently bought all new fuel system components for. My problem is the gauge is still not reading. I have wired everything correct to the diagram and still not showing anything. The gauge shows 12vdc with everything hooked up outside the tank, but as soon as I drop the sending unit in the voltage at the tank drops to 1.25vdc. Any help would be greatly appreciated, this has had me stumped for a couple of weeks now
also should add that whenever i check ohms at the tank with everything disconnected (just sending unit in tank and ground) it shows 30 on my multimeter. Could this mean that I have a hot wire touching the frame somewhere and its causing me to have a bad ground?
54 3100. (pops truck aka my nightmare) 49 3100. restoration project 02 2500. diesel 1/4 mile truck 82 shovelhead. bobber in the making
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | First... Welcome to the forum. The gauge shows 12vdc with everything hooked up outside the tank, but as soon as I drop the sending unit in the voltage at the tank drops to 1.25vdc. Are you saying your taking a voltage reading at the tank sender unit? Your Ohm reading at the sender sounds correct only if your tank is full. Try Pulling your sender and testing it. Should read 0 empty and 30 full The most common problem is a bad ground at the gauge cluster. I made this mistake myself. The gauge must be grounded to the cluster. Also check that the sender is grounded. On my 50 I ran a wire from the sender and it is grounded to the bottom of the Cab. Good Luck | | | | | Joined: Nov 2011 Posts: 4 New Guy | | New Guy Joined: Nov 2011 Posts: 4 | Yes I was taking a reading at the tank sender unit.
Glad to hear the ohm reading is correct.
Where did you ground the gauge to the cluster? I thought it only took the wire from the ign side and one continuing to the sending unit...?
The sending unit is indeed grounded to the cab as well
Thanks for all the help
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | If it’s a new gauge there should be a metal plate on the back. Here is what mine looked like. ...pic... (yours will look diffrent being a 54) That metal plate on the back has to touch metal on the housing. Often times we paint our housings losing the ground. If that ground is good you will have more troubleshooting to do. Good Luck | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Not only that, if it is any way similar to my 49's, if the gauge moves inside the housing at all, you can get a short causing burnt wires (done that) or a bad ground. The 4 gauges in the cluster have individual circuits inside and use the case as a ground. The wire posts protruding out the back of the cluster also hold the circuit in place.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Nov 2011 Posts: 4 New Guy | | New Guy Joined: Nov 2011 Posts: 4 | This is great info to have! Thanks guys, never heard anything about needing it grounded so ill run a wire to ground it while everything is out and hope that this is the problem!
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Number one cause of gas gauge problems, as said, is bad ground. Ground Battery to eng, eng to body, body to frame, sender to frame, gauge to suitable dash spot. ALL grounds have to be bolted to CLEAN metal. Use those grounding "digger" washers. Your whole system will run better. I assume an AD gauge is grounded? I know about TF only.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | patrickm, The 54/55 gauge is a little different from earlier gauges: here are a few photos but the principles-of-operation are the same. As stated above above, bad grounds and no grounds (resulting in a needle "pegged" to Full) are common problems. And, unwanted grounds can also lead to problems. Look at the two photos at the link: 1. In the uninstalled (off) gauge photo, look at the ground metal between the posts and note a circular metal?-thing in the middle, and note that neither post is connected to the ground. The gauge-housing is grounded and it is usually a good ground; however, make sure the gauge attachment-nuts and where they touch the dash are good/clean-metal. NOTE: when the gauge is installed into the gauge housing, neither the fuel-gauge posts nor that circular thing between the posts touches the housing. 2. Look at the installed gauge and notice two things: 1. the red label indicating "sender connection" is on the sender post (and must not be connected incorrectly); and, 2. there is a piece of cardboard that goes on each post and in-between the posts - this is to assure that you do not accidentally touch the wrong lead to the wrong post. The most important ground for the gauge/needle circuit is between the sender "cap" and ground. For diagnosis/testing purposes, I sometimes run a "ground-confirmation" lead from a sender cap nut/screw to the frame or some other good ground (to make sure that a bad reading is not due to a bad sender ground). Good luck, | | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | Sorry to jump in but on my 46 do I run a ground wire from the sender to the frame? Or is there another way? Thanks in advance.
Dan
Trombones Totem Poles And Old Trucks!
| | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Sorry to jump in but on my 46 do I run a ground wire from the sender to the frame? Or is there another way? Thanks in advance.
Dan Yes, sender to frame.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I agree with TC, my opinion is you need a permanent wire from one of the sender mounting screws directly to the frame, always. Tanks are isolated because of the mounting pads and the ground is therefore left to go thru the straps and strap bolts and maybe a little thru the lines. NO GOOD! (TF burbs)
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2011 Posts: 4 New Guy | | New Guy Joined: Nov 2011 Posts: 4 | Thanks for the added info gentleman. I finally got to go take a look at it again today and now this is what I am seeing: The gauge reads all the way past full/pegged out when the ign is off, whenever it is on the gauge reads just past full. Could this be a bad ground somewhere else on the frame? I know for a fact all the wiring is straight, the only one that I havent replaced is the sending unit to the gauge... Also the sending unit is currently grounded to the cab, should I move it to the frame?
Thanks again, patrickm
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | patrickm - Is your gas gauge a 12v reproduction? I installed a 12v gauge from The Truck Shop on my '54 a couple of months ago and like yours, it does not return to EMPTY with the ignition off. Since the gauge is located at 2:00 on the gauge cluster, gravity sometimes pulls the needle past full with the ign off as you describe. Otherwise, it works fine. (FYI - The 12v gauge is manufactured differently than the original 6v gauge. Three coils instead of two). This Fifth Avenute Tech Tip seems to describe your problem: 6) If dash gauge reads, FULL when tank is known to be only half full the wiring between the tank or the sender is bad. Ground the gas tank sender terminal using a jumper wire, if the dash gauge still shows full there is bad wiring between the dash gauge and the tank sender. If the dash gauge goes to empty, the gas tank sender is defective.This is the link to the full article.I made sure that everything is grounded well. - bare metal on the inside of the gauge cluster where it contacts the back of the gas gauge - bare metal on the outside of the cluster where it contacts the mounting nuts, - jumper wire from a good ground to one of the screws that attach the sending unit to the tank. FWIW - I tested my gauge before I installed it, however, it only read EMPTY after I installed it. I found that I had over-tightend the terminal on the sending unit that held the rheostat unit to the round body of the unit. I had collapsed the insulation or maybe rotated the rheostat unit to allow it to touch the body. Good luck,
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Good stuff from LonnieC. My 2 cents: Run separate "test" wires. One from the sender mounting screws to neg batt post and one from sender center tap to gauge. Just use some good wire you have and let it hang loose on the ground, or whatever, just to have a direct bypass of all existing wires. That's how you trouble shoot electrical/all problems. Isolate. Isolate, Isolate. This will tell you that you can eliminate wiring as the culprit and move to sender or gauge or gauge wiring as the problem.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | It's not a truck but I'm working on a 52 chevy sport coupe with the same problem. The sending unit stud on the gauge is showing fully grounded with wire unhooked. I'll have to pull it to see whats causing it. | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | It you look at the back of your gauge you will see the metal plate. It must have good contact with the metal housing. If you cleaned up and repainted the housing make sure you sand off any paint where the gauge will mount so you have bare metal contact with the back or your gauge. Image of back of gauge: http://1954advance-design.com/Web%20images/1954%20fuel%20gauge/rear%20posts%20off.jpg | | |
