| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79747 07/09/2007 7:13 PM | Joined: May 2005 Posts: 19 Apprentice | | Apprentice Joined: May 2005 Posts: 19 | I have looked through the search engine and found some information but I need a couple of more questions answered.
To determine if a Canadian three ton truck has a '270' engine, are the numbers '270' are punched in the number sequence on the boss aft of the distributor? The truck I saw had no typical letter (X, C, XC, G) to start the sequence, nor does it match the number on the door post... please help.
Will this '270' engine bolt in to a Canadian 1949 Chev one ton that had a '216'? What modifications are required?
"Nothing within the realm of the restoration process shall be alien to my experience"
#79748 07/10/2007 4:53 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A 270 will have 270 for the first 3 digits of the serial number.
The GMC engine is longer than a Chevy engine so you will need to move the radiator to make the swap but it has been done. | | |
#79749 07/11/2007 1:20 AM | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | The numbers aren't supposed to match..the numbers on the doorjamb plate are for the cab...
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
#79750 07/11/2007 2:42 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I believe Canadian trucks DO have the engine number on the data plate. | | |
