Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (jmoore, Youngin' Tut 59, Jon G, 51sub, 1 invisible), 109 guests, and 5 robots.
Topics128,288
Posts1,058,574
Members48,492
#797279 11/12/2011 5:14 PM
Need dist 59 Apache trk, (57 235 eng). Going junkyarding. What all year models will work? I want to stay with points. Thanks to all...
Any 54-62 235 distributor will work, as long as the drive gear matches the camshaft. Some engines used cast iron gears, others had steel. Someone should be along shortly to give you specifics about what years will be a drop-in match. The 216 distributors (pre-1954) will bolt in, but the centrifugal and vacuum advance might not be exactly right for your engine. There are at least two different heights of distributor caps and rotors. I think they will interchange as long as both items are used together. The later models had the taller cap. Do you have a distributor now, or are you looking to fill an empty hole?
Have one now I just rebuilt. Just looking for a spare. Thanks
TruckOn #797955 11/14/2011 11:08 PM
Starting with the '54 'glide engines all 235's and 261's use a cast iron cam and the distributor gear also needs to be cast iron. Prior to this, the 235's and 216's used steel cams and distributor gears. You can use any distributor as long as you change the gear to match.
A steel gear is hard to scratch using a small file while the cast gear is fairly easy to scratch. Another way to tell is to look at the shank under the gear, if there is a groove there it is cast, no groove and it's steel. By the way, you can use a cast gear on a steel cam, but you can't use a steel gear on a cast cam.
Thanks, Waldo! I knew there was a specific year range, but I was not sure where the break happened. On the racing scene, we had to use a bronze distributor gear on certain types of roller cams to prevent cam damage.
As is often the case when changes were made around 1953-55, a simple statement that the steel gear changed to the cast-iron gear in 1954 is not completely correct. One has to be careful - people have posted photos of the two gears (Pre '68 Dave?) and that is the best way to be certain of the gear used on a 53-54 distributor.
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0222.htm
http://1954advance-design.com/Web%20images/216-235-261-cams/
