2 members (68ironhead, Napco Man), 218 guests, and 3 robots.
Topics128,081
Posts1,055,955
Members48,430
#796507 11/09/2011 9:10 PM
Took my 216 to the machine shop. The result is that the bores are about 10,000 over standard at the top and needs to be bored - needing oversize pistons. He's suggesting I replace the cast iron with aluminum. Is this a good idea? Does it affect the truck after it's rebuilt in that it's no longer all original?
Thanks Kevin
I think all you can buy now is aluminum. Unless you found a NOS set on epay.
The value of your truck will increase with a rebuilt engine, that costs money!!!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
I just asked Egge Machine and they confirmed that Aluminum is all they cast now days...
Give me ambiguity
or give me something else
If you get new ones made by Egge, then ring design will be different with much thinner rings. That is the way they are made now.
Aluminum pistons are much better for your engine. The cast iron ones create a greater loading on the bottom end and that is not a good thing.
1951 1 Ton Completed
Thanks all I appreciate the advice!! This being my first project and me not being a mechanic...I can use all the help I can get!
Thanks Kevin
The correct way to write 10,000 over is , .010". ( 1,000 over is .001" ). This way will save you a few typing strokes.
Joe
Joe H #796746 11/10/2011 6:09 PM
Makes sense...thanks!
there is a reason they don't make cast iron pistons anymore
He wrote correctly what he thought he heard.
It's not "ten thousand", it's ten thousandths.
One thousandth is .001"
