| | | Forums66 Topics128,135 Posts1,056,422 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 89 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 89 | folks i need your help once again,im in need of a clutch kit for my 1954 chevy pickup 1/2 ton with 235 motor.could you please recommend some brands and part numbers,i called classic parts.they told me the one they carry is a rhino pac ,when i look up that part number on line,it tells me it wont fit my truck,any help would be appreciated. thanks john
| | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | John -
NAPA carries most parts for these older trucks. Give them a try.
Chris | | | | | Joined: Oct 2011 Posts: 89 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 89 | folks im still in need of help with this clutch.The problem is when we got the truck it was all apart.it came with 3 different clutch discs .There was a 10" 11" and a 12" that we found in the bed.so far we have figured out that the 10" that classicparts and jim carter carry ,will not fit, the preasure plate is to small,its not lining up with the bolt holes.did 54 chevy pickups with 235 come with 11" clutch discs?we think the correct one that will work is a 11".thanks folks any help wouls be appreciated. john | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2011 Posts: 89 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 89 | thank you tim,might you know whom might sell the 11" clutch kit for 1954 chevy pickup,235,3100,1/2 ton.I see one listed in classic parts,but it is stating it fits 1969-1984.But they do have it listed under the 54 section.What do ya think on this one?
thank you so much john | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2011 Posts: 89 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 89 | Do you folks know off hand if the 1954 1/2 ton with 235, 11" clutch came with a diaphragm from the factory? If so was it the flat type or the raised type?
thank you john | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | John, Here is a diagram. Replacement pressure-plate assemblies will not look exactly like an original. Good luck, | | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | I have a 54-55 261 with 11" clutch.Sent clutch disk and pressure plate to Jim Carter and they relined clutch and rebuilt pressure plate.I think Patricks has the same service. | | |
