5 members (Jack Ryan, Bill Hanlon, Mike Roache, KEVINSKI, fonz8261), 127 guests, and 2 robots.
Topics128,089
Posts1,056,418
Members48,443
Junior Member
Junior Member
Can this be done? I have a 2 ton 47' chevy with a 53' 235ci, which was just the big bore 216 and I want to know if you can convert the engine from low oil pressure to high pressure. I have roughly heard about it before, like using the crank from a newer inline 6 but I thought they were completely different engines.
thanks
3B Offline
Hy Destry Smith, You would need a different crank, rods, oil pan, and oil pump, and you would have to do something with the oil distribution valve on the side of the block. All in all I would just put in newer full pressure lube engine, hope that helps.
There is an article somewhere on how to do it. You can keep the original crank if you drill it for the oil holes. It's a pretty big pain in the neck.
Paint & Body Shop moderator
Since the later-model high-pressure 235's aren't that scarce or expensive, it makes better sense to upgrade than to undertake an expensive and somewhat risky modification of the older engine. The only advantage I could see to the conversion would be cosmetic, since the appearance of the late 235 is a dead giveaway that the engine has been changed. The tall pushrod cover can't be fitted to the late model engine to make it look like a 216/early 235.
Hotrod Lincoln,4on the floor,and 3B are right on!!!
Youd be better off all the way around to go with a later model 235,,,,over and done. Quick and simple.
But,,,in answer to your original question,yes,it can be done. But spend the extra $$ toward another part of your truck. Youll be glad you did.
Marty
I have one of these converted splash 235s running in my 47 coupe. Has a later full pressure crank, and it takes some machine work to the old block to accept the later crank plus mods to oil passages. However the downside it's a low compression motor only about 6.5 to one plus milling the head on this motor is very expensive as you need to sink in intake valves etc etc.
As stated by the guys above the pressure 235s and 261s are an easy swap. I'm thinking about making the leap to the more modern 250/292 in my old flatbed, with an automatic behind, SWEET!
1946 1/2-Ton Chevy
knuckle head
knuckle head
You can fit a 216 valve cover on a later 235-261 using the 261 hold down studs.If you carefully glue the gasket to the cover,it won't leak.
Need a full oil pressure conversion on a 216? got money to spend? If it's important to you,see these guys Pressure conversion
