1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79658 07/07/2007 12:11 AM | Joined: Mar 2007 Posts: 11 New Guy | | New Guy Joined: Mar 2007 Posts: 11 | Will a chev 6 cylinder 292 fit in my 1947 chev ? Will the motor mounts and bellhousing off my 216 work ? | | |
#79659 07/07/2007 12:42 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | yes, and no. The engine will physicly fit in the engine compartment, but the 292 uses a completely different mounting and bell housing. It uses the side mounts like a V8, and also has the same bellhousing pattern. You'll need to fab the front mounts and use a bellhousing from a '55-'66 V8 truck. I'm certain others can give you more details for this exact swap.
Bill Burmeister | | |
#79660 07/07/2007 6:26 AM | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | the question should be is it worth the exta work to put a 292 in my 47 chev. yes if you have a ad truck use a 54 chev bellhousing x member, and a 55 chev truck v8 bellhousing | | |
#79661 07/07/2007 3:31 PM | Joined: Mar 2007 Posts: 11 New Guy | | New Guy Joined: Mar 2007 Posts: 11 | Thanks for the info.
Bryan | | |
#79662 07/07/2007 7:07 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | What crossmember to use for this swap if I were to use an automatic instead of the stick? I've always herd of the 54 crossmember for stick shifts but could nevery find one. | | |
#79663 07/08/2007 12:19 AM | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | the last 250 with 350 trans swap i did i made the x member it was fast and ez email me at [email protected] and i can send you some pictures | | |
#79669 07/09/2007 9:29 PM | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Here is a pic of a 292 engine mounting crossmember from a 4x4.(1970) The Advance Design frame "channel" height is shorter than the 67 to 72, so the crossmember will require some "trimology" to fit inside the AD rail. | | |
