1 members (Wayne67vert), 111 guests, and 1 robot.
Topics128,035
Posts1,055,566
#79658 07/07/2007 12:11 AM
1 Offline
Will a chev 6 cylinder 292 fit in my 1947 chev ? Will the motor mounts and bellhousing off my 216 work ?
#79659 07/07/2007 12:42 AM
yes, and no. The engine will physicly fit in the engine compartment, but the 292 uses a completely different mounting and bell housing. It uses the side mounts like a V8, and also has the same bellhousing pattern. You'll need to fab the front mounts and use a bellhousing from a '55-'66 V8 truck. I'm certain others can give you more details for this exact swap.
Bill Burmeister
#79660 07/07/2007 6:26 AM
the question should be is it worth the exta work to put a 292 in my 47 chev. yes if you have a ad truck use a 54 chev bellhousing x member, and a 55 chev truck v8 bellhousing
1949 SUBURBAN
#79661 07/07/2007 3:31 PM
1 Offline
Thanks for the info.
Bryan
#79662 07/07/2007 7:07 PM
What crossmember to use for this swap if I were to use an automatic instead of the stick? I've always herd of the 54 crossmember for stick shifts but could nevery find one.
1946 1/2-Ton Chevy
#79663 07/08/2007 12:19 AM
the last 250 with 350 trans swap i did i made the x member it was fast and ez email me at [email protected] and i can send you some pictures
1949 SUBURBAN
#79667 07/08/2007 8:46 PM
here is my 292 w/ offset motor mounts and T5 cross member. a simple box 2x3'' gets bolted to the bottom of the re-inforced frame. I agree w/ rdavid
Quote
if you are using the 292 side mounted then you should remove that crossmember and install one where the rear transmission mount goes. as long as you are using a 3point mounting system no problem.
.... which is what i have done. ALL three ARE rubber mounted. wink
For the rubber mounts, I am using the stock T5 (S-10) part as well as two biscuit mounts for the 292 offset side mounts.
http://www.sachserodshop.com/pdf/5.pdf
Buffalo Steve can fabricate the motor mounts for you if needed
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=010698#000005
my 3104 shots::
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=DSC00367.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=DSC00313.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=579990-R1-016-6A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=579990-R1-020-8A.jpg
hopes this helps you all
Jim & Caroline
#79669 07/09/2007 9:29 PM
Here is a pic of a 292 engine mounting crossmember from a 4x4.(1970)
The Advance Design frame "channel" height is shorter than the 67 to 72, so the crossmember will require some "trimology" to fit inside the AD rail.
Steve
'49 3800
'52 3600
'57 3100
