Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (78buckshot), 43 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#79642 07/06/2007 5:04 PM
Have a '62 with a 6 cylinder. It has a temperature gauge that has lights only, no pointer. When it's cold, it lights green, when the engine warms up, no light, and when it is overheating lights red. Problem: both green and red come on sometimes. 1) Is there a wiring diagram for this ? 2) Where can I get a new sending unit (the unit has 2 wires going to it)?
Thanks is advance
#79643 07/06/2007 9:28 PM
Riding in the Passing Lane
That sender is available at any parts store. I always replace it when I am working on another truck. Then you know it will come on when it is hot. You can test the circuit by grounding one wire at a time with the switch on. The corresponding light should come on. The hot light should also come on when you turn the key to start. That checks the bulb.
1972 Chevy c10 Cheyenne Super
