1 members (Millenimech),
118
Mod | | | Forums66 Topics128,135 Posts1,056,422 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 38 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 38 | Hi everyone, I have a 1961 suburban that will need body mounts this winter. I assume the cab area is the same as a pickup cab. But the rear is a puzzler. I thought it would be similar to the bed mounts of a pickup. The few parts shops I have talked to say no-one sells these mounts and I have been told to use anything from thick leather or rubber to hockey pucks. The actual metal parts of the mounts look OK but I need the rubber cushion parts. Any help would be appreciated.
Remember, for every mile of road, there's two miles of ditch! If you fall on your face, you're still moving forward.
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I bought high density rubber from McMaster-Carr, & re-used my metal bits. | | | | | Joined: Oct 2011 Posts: 38 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 38 | 64fleetside What thickness did you use? did you use one pice or multiple layers?
Thanks Dale
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | IIRC, it was 5/8" thick, oil/heat/ozone resistant high density stuff. I sandwiched it between the OE metal parts, drilled the hole using a holesaw & low speed. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | classic industries has them. they are listed as 69-72 suburban about $13.50 each and you need 16 of them the only cab mounts that you can use from the p/u cab is the frt ones and the "b"pillar ones are to thick the top and bottom insulators have interlocking tabs to keep them in place
a discussion that I had with an old partsman about these insulators.if any one wants a pic of them in good shape to see what they looked like orig give me your email the following is what Lewis Matkin sent to me. the pictures are mine and I will have some more later for you as I have to check something out Ron, this is Lewis. Please forgive me for not getting back sooner, but I have been busy in my work for the church I serve. I checked both my 65-66 parts manual and my 67-72 parts manual. This is what I discovered: 1964-6 body mounts are p/n 3794779, w/dimentions of 1.76" w; 3.00" l; 0.92" thick, needing 8 (up & lwr same). The 67-8 p/n is 3909351 up & lwr, 69-72 uses 3909351 as the lwr, but p/n 3946246 is the upr. No dimentions are given for these cushions, and it seems that the frame changed in '69. Qty's in 67-8 are 16, with 69-72 requiring 10 of each. If you have dimentional axcess to the later cushions, these 64-66 dimentions should help you. Like you, I suspect that the 67-8 cushions will work, but there is no superseded p/n's between the body styles. I can tell you that years ago I bought cab mounts for my 65 and the p/n's had superseded to the mounts for the 67-72 cabs. I hope that this info is of some assistance in answerring this question. the dimensions sound right. the .92" high includes the raised section around the bolt hole. The measurement excl the raised section is between about .73-.74" high hope that helps ron ron | | | | | Joined: Oct 2011 Posts: 38 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 38 | Thanks guys This gives a direction to follow. We use McMater Carr for a lot of parts at work I will check them out. I will also check out classic industries. Just trying to get my ducks in a row before snow hits and the truck goes in the shop for the winter for a bunch of work. Thanks again Dale
| | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | you can use the 69 mounts, The frame holes are 3 different sizes. For the holes that were to small I cut off the little interlocking lips then used heater hose to keep ferrule from hitting the frame. Works great. The last time I bought them they told me they were the last sets in stock! (sorry) lol. Cut hose about 1/2 shorter than two mounts plus frame thickness. Some of the ferrules might be different lengths too so make sure they are short enough to allow for compression when you tighten the bolts! | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | may have some old nasty ones and 2 new by the way. Bolts are different thicknesses and lengths too! | | |
