| | | Forums66 Topics128,130 Posts1,056,713 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79639 07/06/2007 4:10 AM | Joined: Dec 2006 Posts: 22 Apprentice | | Apprentice Joined: Dec 2006 Posts: 22 | Hello. I've got a drivetrain out of a 93 Buick Roadmaster that I want to transplant into my 72 Chev PU. It's actually a Chev 350 with throttle body injection and a 700R4. It seems like a straightforward swap. Is there something I should be aware of that I'm not thinking about?
Fleetside Bob
#79640 07/06/2007 4:35 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy bobtheinsman, A high pressure fuel pump and a return line to the tank from the pump, a non resistant ignition wire for the distributer are a couple of things that I thought of, hope that helps, | | |
#79641 07/06/2007 2:52 PM | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | Unless the truck already has one, you will also need a brake switch to disconnect the converter lock up when the brakes are applied. I also think that the 700R4 is slightly longer than the automatic ( I assume your '72 is auto) in the truck now, so an engine mount revamp is in order. | | |
