5 members (Gdads51, Rich'sToys, jasrking, TooMany2count, FishinToms53), 117 guests, and 1 robot.
Topics128,126
Posts1,056,354
Members48,441
Apprentice
Apprentice
Hello. I've got a drivetrain out of a 93 Buick Roadmaster that I want to transplant into my 72 Chev PU. It's actually a Chev 350 with throttle body injection and a 700R4. It seems like a straightforward swap. Is there something I should be aware of that I'm not thinking about?
Fleetside Bob
3B Offline
Hy bobtheinsman, A high pressure fuel pump and a return line to the tank from the pump, a non resistant ignition wire for the distributer are a couple of things that I thought of, hope that helps,
Unless the truck already has one, you will also need a brake switch to disconnect the converter lock up when the brakes are applied. I also think that the 700R4 is slightly longer than the automatic ( I assume your '72 is auto) in the truck now, so an engine mount revamp is in order.
