5 members (UtahYork, BC59, JW51, Otto Skorzeny, Gdads51), 248 guests, and 3 robots.
Topics128,089
Posts1,056,129
Members48,435
#795370 11/05/2011 1:56 PM
O.K. this is a new thread following my No Spark one.
Update. I have fuel, Have a good spark( may coil tested bad in the secondary circut) with new coil but still no start.
So, now I sit an think what did I do wrong.
Timing gears on the money(dot to dot on gears),every bolts tighted to spec, holycow I did not adjust my rockers correctly! I just tighten them down without finding TDC on each cylinder.
I need assistant on this procedure. Do I rotate the pushrod side to side or do I lift it up and down for adjustment? Do you guys think I bent a pushrod? I would like an explanation of the valve layout, starting with the one closes to the front of the engine example intake,exhaust right on down the line. THis way I will know which one is correct. I have a 292 engine.
The simplest way to tell if you're working on intake or exhaust valves is to look at the corresponding manifold runner. Other than the very end valves front and rear (which are both exhaust, BTW), two valves will share a single manifold runner. Counting from the front, here's the layout:
E-I-I-E-E-I-I-E-E-I-I-E
The pistons on two cylinders reach TDC at once, one on compression, the other on exhaust. These are known as "companion cylinders". Here's the companion cylinder pairs:
1-6
2-5
3-4
To get an accurate position for valve adjustment, watch the valves on the companion cylinder to the one you're about to adjust. As one cylinder reaches the top of the exhaust stroke, the exhaust valve will be closing, and the intake will be starting to open. This is known as "rocking". At the same time, the companion cylinder will be at the top of its compression stroke with both valves closed. Turn the engine clockwise at the harmonic balancer, either by putting the vehicle in gear and rolling it forward, or using a socket on the crankshaft pulley bolt, and watch the valves. Watch the #6 valves. When #6 is rocking, adjust intake and exhaust on #1. Continue until all the valves are adjusted. It will require two turns of the crankshaft to adjust the valves on all six cylinders. Here's the sequence:
Rock #6, adjust #1
Rock #2, adjust #5
Rock #4, adjust #3
Rock #1, adjust #6
Rock #5, adjust #2
Rock #3, adjust #4
To adjust hydraulic lifters, back the rocker nut off until there is plenty of slack in the pushrod with the cylinder at TDC on the compression stroke, then tighten the nut slowly until all the slack is gone. If the pushrod turns easily, there's still some slack. Once the slack is gone, turn the nut another 3/4 turn. Adjust both valves before moving the engine to the next TDC position. Good luck!
1-6
2-5
3-4
Rock #6, adjust #1
Rock #2, adjust #5
Rock #4, adjust #3
Rock #1, adjust #6
Rock #5, adjust #2
Rock #3, adjust #4
When you state rock, can you explain what does that mean?
It's in the third paragraph of the post you just quoted.
Thank you HotRod Lincoln
Your the man, your explanations are tops.
I beleive you should write some tips for the forum.
Thanks again
Finally a start!!!!!!!!!!!!
I now have to fine tune things,
Thanks to all
