| | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | I purchased a 46' this summer and it is missing two sunvisors. The holes are there, but no visors. Would a 1947 GM sunvisor from Lebaron Bonney fit my application for a 46'? Holes in the same configuration, size, etc.? Thanks. Jim- | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Hello, I do not think the 46 had interior sunvisors. Perhaps someone has a differen opinion. Yours may have been added by a previous owner. Harold 11/12/11 Correction to above. Someone sent this info to me. It appears a Sun Visor was available as Optional Equipment. Sun Visor, Option 261, from 1946 Salesmans Data Book. Harold
Harold Is a restoration ever finished? | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I second Harold 46's comment. My '40 is pretty original. The header panel doesn't have any holes for visor mounts. I have looked around a bit ( Carters, Chev's of the '40's ) for stock visors as they would be nice to have, with no success. I also grabbed a pair out of a BMW 6 series at the wrecking yard a few years ago, but decided against installing them. | | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | Ditto as well. Not only that, but I find that windshield is so far away and so low relative to my eye level, it hasn't been an issue. Mine had a drivers side when I bought it but I chose not to put it back on.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
| | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | I have a 36 Suburban that I'm restoring..and it had a sunvisor for driver only..it wasn't there, but found the bracket and a small corner of the cardboard it was made from on the floor. Where would one get the correct vinyl or cloth to cover, and does anyone know what the panel truck or suburban sunvisor looked like? | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | The visor had the same material and color as the seats. Drivers side was usually standard, passenger side was optional. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | This is to correct my Post dated dated 11/7/11 I edited my post to include this info. Someone sent this info to me. It appears a Sun Visor was available as Optional Equipment. Sun Visor, Option 261, from 1946 Salesmans Data Book. Harold
Harold Is a restoration ever finished? | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | They were dealer installed options. Look at page 315 Suburbans had the same options
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | |
