4 members (Deegs53, CuzzFuzz, 52Carl, 1 invisible),
111
Mod | | | Forums66 Topics128,140 Posts1,056,466 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | trying to rebuild this motor? used the #s game) block casting# 2324002- 1955to62-)248 or 302 head casting# 2136477- (39to52- 228) or 46to52- 270 crank forging# 2191127-(39to52- 228) or 53- 248 camshaft forging# 2192486 (54- 270) or 52-54 302 connecting rod forging# 2135419- late 270 early 302 guy said it ran good,I never heard it. Does anyone know if this combo of parts will be ok, I worry about the domed pistons hiting valves. crank and block 248 rest looks like 270? any help is welcome thanks Bill | | | | | Joined: Feb 2004 Posts: 29,819 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,819 | If it was running with that combination of parts, you probably don't have anything to worry about. Here's a method we use to check valve-to--piston clerarance on the race engines- - - -Turn the assembled engine over by hand, after adjusting valve clearance to spec, until the intake and exhaust valves are partially open and the piston is at the top of the stroke. (TDC on the exhaust stroke). Then use a pry bar or other method to push the valve down to contact the piston, and measure the travel. It's simplest with a dial indicator resting against the valve retainer. You're looking for at least .100" of clearance with the piston at the top of the stroke. Jerry
#7961 02/28/2004 11:10 PM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | HOTROD LINCOLN thanks I will check valve clearence when motor is reassembled. It's the casting #s showing different size motors that mixes me up, I think that valve to piston clearence is all there is to worry about?? all the parts I need are available, so far. thanks Bill | | |
