5 members (klhansen, 52Carl, 55shaker, Shardean, Ponchogl), 87 guests, and 3 robots.
Topics128,022
Posts1,055,352
Members48,420
#795841 11/07/2011 8:48 AM
Should there be two seat frame springs like this , one for each side ?
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
Just went out and looked at my ‘54 which is quite original and there is only one spring on
it. Both holes are there for a spring on the passenger side but my thoughts are that it
may be kind of hard for the driver to push the seat back with a spring on the
passenger side, unless he scooted over to the middle of the bench.
Interior looks great, where did you get your paint for the interior and can you
give us a number???
DG.
Denny G
Sandwich, IL
Thanks for looking Denny, I kind of thought there was only one spring... The Assembly Manual Sec. 1 Sheets 2.00 - 2.05 pictures are the seat instructions...
The paint is SEM COLOR COAT AEROSOL PESCADERO SAND 15383... It goes on really nice, dries fast, seems to be pretty durable... It does cost a lot more then Rustoleum but is worth it... Dash pic... I do not have a set up for painting so its shaker can for now...
The paint store I got it from also has the old paint codes for GM... When I can afford a exterior paint job I will go there for the Mariner Blue...
Moderated by  ndkid275, Phak1
