| | | Forums66 Topics128,049 Posts1,055,548 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | what type of paint do you use for general body panels
only in the uk were a getting pushed by european law as to what type we are allowed(supposed)to use whats easiest to use without to much fuss and not in best spray shop(booth)conditions..
live or die do it with spanner in hand
| | | | | Joined: Dec 2010 Posts: 44 New Guy | | New Guy Joined: Dec 2010 Posts: 44 | Hello Spanners, If you are going with a solid color, I would suggest a single stage polyurethane paint. These paints hold up extremely well and require fewer overall coats as compared to a base coat/ clear coat system. Fewer coats of paint mean less VOCs in the air and everyone is happy. The single stage paint systems generally require a catalyst and possibly a small amount of reducer. You seal the panels, and apply 2-3 coats and your done. If using base coat/ clear coat you would have to apply 2-3 coats of base color and then 2-3 coats of clear. Companies like PPG, Dupont and Sikkens all have single stage paint lines.
Hope this helps. Hope this helps.
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | All well and good. But, single stage paints are harder to repair, blend, etc. I have not decided how to go, but will probably go single stage Dupont Nason paint for interior and exterior. | | |
