9 members (warlock, mick53, 55shaker, fonz8261, Ponchogl, RoadsScholar, Gdads51, Otto Skorzeny, 32Fordpuchoptop),
105
Mod | | | Forums66 Topics128,048 Posts1,055,626 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 96 | my fuel tank is in pretty decent outside condition but the inside is rusted, what is the best way to clean out the rust so I can coat it, I had gotten some POR15 from Napa. | | | | | Joined: May 2011 Posts: 99 Shop Shark | | Shop Shark Joined: May 2011 Posts: 99 | I recently went through the same thing. I brought it to a radiator shop to be boiled out. After they looked out it they told me it would also need to be coated. I ended up buying a new tank since the cost was about the same as cleaning and coating the old tank. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You can buy kits that contain a mild acid to clean the tank and a liner. I've used that type of kit in the past but I discovered that using muriatic acid is much quicker. Also note that because it's a much more caustic acid the safety requirements are more stringent. I used muriatic acid to clean my '38s tank because replacement tanks are not available. I then dumped several gallons of soda water into the tank to kill the acid, rinsed well, let it dry and coated with Redkote liner after brazing the larger holes shut. Five years now and no issues.
| | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | Take it to a radiator shop and have them boil it. Something that big would be best done there. You don't have to worry about disposing the acids. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | IF you're lucky enough to have a radiator shop that will touch it. None around here will come close to an old gas tank.
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I'll add my experience. I had a '66 tank with bad rust. I bought Muriatic acid at Lowes and followed the directions on the Eastwood Gas tank repair kit I had purchased. I had to acid wash the tank more than they said, but I was happy with the rust removal. The white sealer was more than enough, so you might start by using only 3/4 of the bottle. Overall, I was pleased with the results. I hear that POR-15 makes a nice kit too. One thing to keep in mind is that neither kit contains the Muriatic Acid, even though the POR-15 kit says it's complete. I imagine it has an acid wash, but I say get the gallon of Muriatic at Lowes and then you will have everything you need. http://www.eastwood.com/ew-gas-tank-sealer-kits-for-cars.htmlhttp://www.por15.com/FUEL-TANK-REPAIR-KIT/productinfo/FTRK/ | | | | | Joined: Sep 2010 Posts: 72 New Guy | | New Guy Joined: Sep 2010 Posts: 72 | I'm with Lugnuts - DIY!!!!! Eastwood's kit is the BEST out there. You suppky Muriatic Acid and baking soda and go to town. It's not that hard and the sealer coats it beautifully.
I've done several tanks with it now and they are all perfect.
I have an article on it on my website. | | | | | Joined: Apr 2011 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 96 | I went with phosphoric acid then let vinegar sit in there and shook some sand around inside it to knock the rust off then drained and rinsed then rinsed and rinsed again, let it dry and coated it with POR15 I'm letting it dry right know, hopefully it will work out. | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | The last tank I had I took to a local radiator shop. They boiled it out, & redkoted the inside for about $100. No mess, no clean up.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | |
