5 members (1955 1 Series, Southerntruck, tclederman, Rusted Nut, Peggy M), 38 guests, and 8 robots.
Topics128,010
Posts1,055,308
Members48,419
#795019 11/04/2011 12:15 AM
guys,
im running a sbc 350 in my 57. i swapped out the aluminum pulleys that were on it, crank and water pump, for some chrome steel pulleys, hoping to get rid of the belt squeal i was getting with the aluminum pulleys.
question..... the aluminum pulleys, both crank and water pump, were the same diameter, 6.5". the new chrome pulleys are different diameters, with the crank a little bigger, say 7" diameter, and the water pump pulley smaller, say 6" diameter. will my water pump and alternator run the same speed as before, of will they run slower or faster now ? the belt length is the same.
just curious.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
Your water pump and alt. will run faster.
Joe
Joe H #795113 11/04/2011 9:20 AM
thanks joe...
