0 members (), 153 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
#79490 07/02/2007 7:51 PM
Does anyone know what the rear end ratio would have been a 1970 Chevrolet truck with automatic transmission? Is there any way to know for sure?
#79491 07/02/2007 9:17 PM
Riding in the Passing Lane
Probably a 3.08. You should examine the diff. to be shure.
1972 Chevy c10 Cheyenne Super
#79492 07/03/2007 2:07 AM
Dennis,
Jack up one wheel, mark the tire and the driveshaft. Turn the wheel two complete revolutions and count the turns on the driveshaft. It will get you close.
Fred
#79493 07/03/2007 3:33 AM
My '72 is about 3.5 to 1. Maybe 3.53?
#79494 07/03/2007 3:43 AM
The only part i know is 3:73
11 teeth on the pinion,41 teeth on the ring.
41 divided by 11 =3:73
Pull the inspection plate off,,count the teefers on both gears,and divide.
#79495 07/04/2007 5:10 AM
Junior Member
Junior Member
I just got a rear end from a 70 gmc pickup,and it is a 3.73:1 it has a clutch and spring pack posi
#79496 07/04/2007 10:13 PM
I found one with a 3.08 gear however it was 2" wider thatn my existing rear end. It was from a '69 Chevrolet truck.....WHY?
#79497 07/04/2007 11:25 PM
Quote
It must be a 1970, 63-mid 1970 rears are 1 1/2" narrower than mid 1970-up, dunno why unless they were gearing up for the(wider)disc brakes that came in 71. The 70 rear is a one year only, being 6 lug & wider than the 63-mid 70 rearend.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
