| | | Forums66 Topics128,105 Posts1,056,205 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79490 07/02/2007 7:51 PM | Joined: Aug 2004 Posts: 54 'Bolter | | 'Bolter Joined: Aug 2004 Posts: 54 | Does anyone know what the rear end ratio would have been a 1970 Chevrolet truck with automatic transmission? Is there any way to know for sure? | | |
#79491 07/02/2007 9:17 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Probably a 3.08. You should examine the diff. to be shure. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#79492 07/03/2007 2:07 AM | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | Dennis, Jack up one wheel, mark the tire and the driveshaft. Turn the wheel two complete revolutions and count the turns on the driveshaft. It will get you close. Fred
#79493 07/03/2007 3:33 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | My '72 is about 3.5 to 1. Maybe 3.53?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#79494 07/03/2007 3:43 AM | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | The only part i know is 3:73 11 teeth on the pinion,41 teeth on the ring. 41 divided by 11 =3:73 Pull the inspection plate off,,count the teefers on both gears,and divide. | | |
#79495 07/04/2007 5:10 AM | Joined: Feb 2007 Posts: 13 Junior Member | | Junior Member Joined: Feb 2007 Posts: 13 | I just got a rear end from a 70 gmc pickup,and it is a 3.73:1 it has a clutch and spring pack posi | | |
#79496 07/04/2007 10:13 PM | Joined: Aug 2004 Posts: 54 'Bolter | | 'Bolter Joined: Aug 2004 Posts: 54 | I found one with a 3.08 gear however it was 2" wider thatn my existing rear end. It was from a '69 Chevrolet truck.....WHY? | | |
#79497 07/04/2007 11:25 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Originally posted by Dendo: I found one with a 3.08 gear however it was 2" wider thatn my existing rear end. It was from a '69 Chevrolet truck.....WHY? It must be a 1970, 63-mid 1970 rears are 1 1/2" narrower than mid 1970-up, dunno why unless they were gearing up for the(wider)disc brakes that came in 71. The 70 rear is a one year only, being 6 lug & wider than the 63-mid 70 rearend. | | |
