4 members (Peggy M, Gib70, Gray_Ghost, 1 invisible), 252 guests, and 2 robots.
Topics128,089
Posts1,056,117
Members48,434
I tell you, the gods of heater control valves are looking down upon me today.
My original HCV leaked so I bought a reproduction. It didn't fit properly, was poor quality, and leaked in less than a year.
I bought a NAPA replacement diaphragm and attempted to repair my old one, thinking I'd send it out to a rebuild service if it failed.
A bench check of my repair efforts showed it was unsuccessful, so I took the original, the repro, and my heater core to the local radiator shop for him to do full-up testing to find out the extent of the problems.
I talked to the shop today: he REPAIRED my old valve, said the repro had no value, and verified the core had no leaks. Total cost: $40.
This is much cheaper (at least half price) than sending it out to a valve repair service. You might consider checking your local radiator shop if your valve leaks. I did this on impulse and am glad I did.
thumbs_up thumbs_up thumbs_up
Thanks for letting us know Bill. I think I will check back with the shop that tested my heater core to see if they rebuild the Ranco valves.
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
Leo Offline
Moderator
Moderator
Good tip, Bill. Our local rad shop has an excellent technician.
there is a guy who rebuilds the ranco valves at heatercontrolvalve.com. He does the Harrison valves also. Round $90 and he has a warrenty on all his work.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
That's one of the rebuild services that was my "plan B" in case the radiator shop job failed. My point is that I was able to shop locally for half price.
I'm not disparaging heatercontrolvalve guy's work because I've never used it. In fact, I thought he (among a couple other outfits) was the only option I had. Turns out I found a local option that was more competitively priced.
It's possible to buy a brand new Ranco HCV from Sweden. These run ~$125 + freight. Still another option for those who no longer have cores.
I bought the valve at napa for about $10. Rebuilt the control valve today. Works fine now.
Dennis
Just shows you what good things can happen when we think outside the box. dang
~Jim
