Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (MNSmith, dt235sd, J Lucas, Hotrod Lincoln), 199 guests, and 6 robots.
Topics128,288
Posts1,058,579
Members48,492
#794471 11/02/2011 3:52 AM
Any one know where I can get some cheap hydrolic lifters for a full pressure chevy 235, it's a 1953. I've found them for $12 a piece. I just find it annoying that Summit sells a wide selection of lifters for $3 a piece, just not the size of the 235. They're pretty big in diameter, 0.989 in.
It's not the size that matters guy, it's the volume of sales that drives the cost. Taint as
much demand for Stovebolt lifters like there is for the V8s.
Heck, you can put a whole SBC together for half the cost of a Stovebolt rebuild.
DG
Denny G
Sandwich, IL
You're very right,I have a 235 that I was wanting to rebuild but the parts for it keep going up and up and up after more research. For some reason I though these were more common than they are.
I rebuilt a 350 about 10 years ago when I was just out of highschool for my Blazer. I think back then I spent 500 for all the machine work and a master engine rebuild kit. A master rebuild kit from Kanter, Egge, and others is well over $1,000 for a 235, just too rich for my blood.
So...did a little more research and have decided to go with a 1964-1975 Chevy 250. They have design upgrades and you can get parts at a very resonable price. Langstroms sells bolt in engine mounts for 150 and I'll have a modern style Chevy bellhousing bolt pattern. The Chevy 250s are starting to seem fairly plentiful to, by try and find a 292.
