5 members (Joe H, Cosmo, Otto Skorzeny, Phak1, Bill Hanlon), 128 guests, and 1 robot.
Topics128,049
Posts1,055,548
Members48,425
#794199 11/01/2011 1:37 PM
Have a CPP PB kit in my '61 C20. Pulling vacuum off the head (stock 235), and it's pretty weak at idle--as in easing up to a stop light. Noticed elec vacuum pumps in several catalogs to help maintain pressure for people running cams in their SBC's. Milling the head for more compression not in the budget right now, plus the old girl starts every time. Thoughts from the brain trust? Ray in Va Beach
Theres always the hydroboost systems that function off of the p/s pump, but they aren't very budget friendly. Do you have a vacuum guage? Was wondering how much vacuum your getting.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
Don't have P/S yet, still working on the bracketry for the 235. Had 12/13lbs just above idle last time we checked. What I'm reading says a steady 15/16 is what I need.
Nomad;
You could try a vacuum reservoir/tank. That's another solution the guys with radical cams run. See these from Summit:
http://www.summitracing.com/search/Part-Type/Vacuum-Reservoirs/
I would think you should have enough stored vacuum for stopping at a red light.
SimS
Agreed, vacuum tank would be the most budget friendly and they work well.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Z
Z Offline
Nomad02, Sent you a PM
