| | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 1 New Guy | | New Guy Joined: Oct 2011 Posts: 1 | My first post, but I'm sure not my last. My son and I are starting our first rebuild together - a 65 stepside. He is 14 so we have a couple of years to get it done before he starts driving. I came across a 1984 1/2 ton chevy - transmission's shot and the body is really rough, but it was free. I've learned through these forums I can do some upgrades to the 65 from the 84 - crossmemebr swap, power brakes and steering, etc. Swaping out the front gives 5 lug up front, but 6 in the rear. Can I just swap the rear end out of the 84 into the 65 to give the rear 5 lug? | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | I think that you'll have to measure the length of the rear ends | | | | | Joined: Dec 2009 Posts: 18 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 18 | There are a few good threads on this subject here and on the 67-72 forum. Width of the '84 will be something to check, and you will also have to convert it to work with coil springs, its likely a leaf sprung rear end.
You can buy the coil spring mounts and weld them to it, but may be easier to find a 71 or 72 rear end thats coil spring and 5 lug.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You're going to find that the '84 rearend is about 2" wider. That really shouldn't be much of a problem. Something you might consider doing that will reduce the work is to do an axle shaft swap. The shafts from the '84 will work in the '65 rearend, they just need to be shortened to the same lenght as the oeriginal axles and regrooved for the C clip. Any competent machine shop should be able to do that. Use the drums from the '84, the rest of the brakes can be '65.
Bill Burmeister | | |
