| | | Forums66 Topics128,108 Posts1,056,566 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 163 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 163 | I own a late '47 chevy coe and i would like to keep it as original as possible, but i am having a hard time finding an updraft carb and intake. Also i am not sure if a 235 is big enough to keep the wheels turning to stay up in todays traffic.
I have a bbc and turbo 400 if i were to upgrade. I just dont like the look of the engine behind the caband i would like to keep as much of a flatbed area as i can. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Try to find a 261 engine... it will keep up.
My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Even with enough power you're not going to keep up with todays traffic unless you address the gearing situation. It's geared really slow now so more power is only a small part of the equation. Also consider brakes if you'll be hauling stuff and traveling fast.
Grigg | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What rear end do you have? Even a 261 (or GMC 302) would be revving quite high to get you up to 65mph. Fill in your rear-end ratio and tire diameter and let us know the RPM at 65mph. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 65mph 35" tires SM420 transmission 1:1 in high gear 5.43:1 rear end ratio =~ 3400 RPM 6.17:1 rear end ratio =~ 3850 RPM
| | | | | Joined: Aug 2009 Posts: 163 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 163 | I found a 1952 chevy coe that is complete. I need to get some cash together and i will have an engine and trans and everything i need for the '47. I figure i can customize the '52 if i get it. The '52 is rusty.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I have seen many V8's in COE's, since the V8's are shorter in height, they easily fit in the 6 Cyl. place, not requiring putting them in the bed, however, I would go w/ a 261 , or even better, a GMC 302. Just move the radiator in front of the core support, find an OD trans., upgrade the braking system.
