2 members (klhansen, Danielbolt), 114 guests, and 1 robot.
Topics128,103
Posts1,056,534
Members48,448
#793982 10/31/2011 5:01 PM
I own a late '47 chevy coe and i would like to keep it as original as possible, but i am having a hard time finding an updraft carb and intake. Also i am not sure if a 235 is big enough to keep the wheels turning to stay up in todays traffic.
I have a bbc and turbo 400 if i were to upgrade. I just dont like the look of the engine behind the caband i would like to keep as much of a flatbed area as i can.
Try to find a 261 engine... it will keep up.
My Chevy Viking 1959
Ulf Hedlund. Eskilstuna. Sweden
[email protected]
Also:
Ford Galaxie 4 dr 1959
Ford Custom 4 dr 1964
Ford Mustang GT 2005
Even with enough power you're not going to keep up with todays traffic unless you address the gearing situation. It's geared really slow now so more power is only a small part of the equation.
Also consider brakes if you'll be hauling stuff and traveling fast.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
What rear end do you have? Even a 261 (or GMC 302) would be revving quite high to get you up to 65mph. Fill in your rear-end ratio and tire diameter and let us know the RPM at 65mph.
65mph
35" tires
SM420 transmission 1:1 in high gear
5.43:1 rear end ratio =~ 3400 RPM
6.17:1 rear end ratio =~ 3850 RPM
I found a 1952 chevy coe that is complete. I need to get some cash together and i will have an engine and trans and everything i need for the '47. I figure i can customize the '52 if i get it. The '52 is rusty.
Crusing in the Passing Lane
I have seen many V8's in COE's, since the V8's are shorter in height, they easily fit in the 6 Cyl. place, not requiring putting them in the bed, however, I would go w/ a 261 , or even better, a GMC 302. Just move the radiator in front of the core support, find an OD trans., upgrade the braking system.
