5 members (EchoBravoSierra, BarryP, Otto Skorzeny, Shade Baby, Phak1), 156 guests, and 1 robot.
Topics128,162
Posts1,056,910
Members48,458
#793944 10/31/2011 3:07 PM
I have a 49 suburban with a new 0-30 ohm sender in the tank hooked up to the factory gauges. I'm not sure if the gas gauge in the cluster is 6V or 12V (or if that matters). When I turn on my key, the fuel gauge goes right over to F and a little beyond. The gas tank is near empty. Any help with some troubleshooting tips would be appreciated. My truck has been converted to 12V
Maybe the sending unit wire is accidently grounded somewhere?
Craig
I think that means the float is stuck, or the resistance, ain't resistancing. By that I mean that perhaps the wire has come off the sender, or you've lost your ground. If I recall correctly, the higher the level in the tank, the more resistance in the circuit, That why I'd imagine the resistance ain't resistancing.
Have you pulled the tank from the truck?
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
If your truck is 12-volts and your dash gauge is the stock one... you need to install a "Runtz" on the back of the fuel gauge to reduce it back down to 6-volts. Your 0-30 ohm sender is correct so you should live happily ever after.....
Where does the sender ground? Is it through the mounting screws itself to the tank? I guess I could jump it to find that out first right? If that doesn't work, then I guess I'll drop the tank. For clarification, When it's all the way to 'F' does that mean no resistance or full resistance? (I guess if I knew that, i'd have my answer about ground)
I'm pretty sure my gauge is 12V. Maybe the wires are reversed on the back of my gauge?
My understanding is Full = no resistance.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
That happened to the aftermarket 12v gas gauge on my '54 (converted from 6v to 12v). I had overtightened the contact to the wire on the sending unit. Must have collapsed the insulation and grounded it out. Backed off the nut a little and solved the problem.
- Lonnie
My '54 3104
I'll check the sending unit wire for tightness, and I'll check for a bad ground. Thanks for the super quick responses!
I had this happen on my '51 suburban and I went about 5 years worrying about running out of gas before I finally dug into it.
I had the instrument cluster out as part of a rewire. I inspected the gas gauge and found that the fibre board backing up the contacts had warped and was grounding the gauge. I was able to straighten and reinforce this plate, and the gauge has worked just fine for the past 10 years.
Hey we still need to get together.
Kurt -Burb owner in Raleigh of long standing-
