8 members (Forty9, Joe H, MickeyP, FAST55, 55shaker, 68ironhead, LAROKE, 1 invisible),
63
Mod | | | Forums66 Topics128,175 Posts1,057,118 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Hi Guys,
I thought it would be neat to have a pair of 6 volt wig/wags on the back and front of the old '52 firebolt.. I know I need a 6vt flasher but need a source for 2 6vt relays...
Thanks! | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | I know on buses, they typically use a Flasher unit feeding a Bosch Relay to get the flashing lights. Not sure if there's a 6-volt Bosch relay or not.
There also is such a thing as an Alternating Flasher unit, which would be simpler, as it does it all in one unit. Here again, don't know if a 6-volt alternating flasher exists . . .
-Michael
| | | | | Joined: Mar 2010 Posts: 18 New Guy | | New Guy Joined: Mar 2010 Posts: 18 | On my truck (all 6 volts) the siren-flasher has a flasher unit just for that purpose. The power comes from a new fuse relay ( That I added ) to a switch on the dash to the flashing unit and then to my siren-flasher. If you want your light to flash independently you will need 2 flashers units. One flasher unit could do the two lights but they will be flashing together.
Hope this help. Lieut DGoss | | |
