| | | Forums66 Topics128,121 Posts1,056,328 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | I have six cars in an unheated garage, all enclosed and not heated..Up here in Idaho, it gets down to 10 above, should I remove batts to a slightly warm garage..and battery tend them, or loosen the neg cables and be done with it? | | | | | Joined: Jan 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 55 | why not put keep them in the vehicles and put a tender on them? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | We take the batteries out of our stuff in the winter and bring them into the shop. I have a battery tender that I put on for a week and then move it to another battery. In the spring I check them with a load tester to make sure the battery has a full charge in and then install it. Been doing this for years with good success. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have just left my 6v Optima batteries in the vehicles the past three years. No problems starting in the Spring (it sometimes gets to 20 below here).
However, using a battery tender in the truck, or on the battery in a heated or unheated garage, or bringing the battery into a warm room cannot hurt and might even help the battery life.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I open the disconnect on my battery and hook up a battery tender that uses the "float" technology. Temperatures of -25 F are not unusual where we live. I don't run my truck in the cold weather so it sits that way until spring. | | | | | Joined: Feb 2004 Posts: 29,808 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,808 | A battery will slowly self-discharge unless the engine is started periodically and run for a few minutes, or some sort of trickle charger is used to maintain it. Discharged batteries can freeze, but it's almost impossible to freeze a fully-charged one. The best possible situation would be to store them in an area that does not go below freezing, and use a trickle charger or a battery maintainer to keep them charged.
Even if it does not freeze, a discharged battery that stays that way for several weeks will develop hard crystals of lead sulfate on the plates, and it will be extremely difficult to recharge. Keeping a battery fully charged at all times is the best way to assure it has a long, useful lifespan. Rule #2 is keep it bolted down- - - -bouncing around destroys a battery in a hurry. Jerry
